Hej stoję przed kupnem ibizy 6l 1.2 12v 64km 2002r linka macie tutaj - https://www.olx.pl/oferta...D5-IDmPaJE.html
Obejrzalem auto i stwierdzam tak, lekko telepie silnikiem (mozliwe ze poducha)
facet wymienil sprzeglo i lancuch.. generalnie jest ok ale sa bledy na kompie podaje tutaj:
VCDS-Lite Version: Release 1.2
Tuesday, 20 June 2017, 18:04:38:0
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56
Address 01: Engine Labels: Redir Fail!
Controller: 03E 906 033 D
Component: 1,2l/4V SIMOS3 00HS7000
Coding: 00071
Shop #: WSC 42269
VCID: 21356687B8D1
VSSZZZ6LZ2R030239 SEZ7Z0B1530707
No fault code found.
Readiness: 1110 0101
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.LBL
Controller: 6Q0 907 379 G
Component: ABS 5.7 FRONT V20
Coding: 00044
Shop #: WSC 00000
VCID: 41F5C6075891
Address 08: Auto HVAC Labels: 6Q0-820-045.LBL
Controller: 6L0 820 045
Component: Klimaanlage X0840
VCID: E5BDB2976C79
6 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to Plus - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-00 - Open or Short to Plus
29-00 - Short to Ground
28-10 - Short to Plus - Intermittent
28-00 - Short to Plus
00898 - Control Circuit A/C compressor
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.LBL
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 16396
Shop #: WSC 06402
VCID: 3A07B1EB3547
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 6Q0 909 605 S
Component: 06 AIRBAG VW5 02 0007
Coding: 22838
Shop #: WSC 06441
VCID: 47E1D81F76B5
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 6L0-920-xx0-17.LBL
Controller: 6L0 920 801 fu
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 00137
Shop #: WSC 00000
VCID: D5DD82573C19
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 06402
VCID: F093D3C3A3BB
Address 25: Immobilizer Labels: None
Controller: Bit teA dre ssu
Component: e 17 eingeben
VCID: CFD1703F1EC5
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 44: Steering Assist Labels: None
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00111
Shop #: WSC 06402
VCID: 3905AEE73041
Address 46: Central Conv. Labels: 6Q0-959-433.LBL
Controller: 6Q0 959 433 E
Component: 4x Komfortgerát 0001
Coding: 00065
Shop #: WSC 06402
VCID: 3D0DBAF72469
End --------------------------------------------------------------------------------------------------
- Forum mechaników samochodowych - forum-mechaniczne.pl Forum mechaników samochodowych Mechanika Forum Samochodowe Seat
Ibiza 6l 1.2 - odczyt błędów komputera
Forum seat
