{"name":"Portal mechaniczny - samochody, nowo\u015bci, mechanika pojazdowa","description":"Serdecznie zaprsazamy na nasz portal po\u015bwi\u0119cony mechanice samochodowej oraz motoryzacji i nasze forum: forum-mechaniczne.pl","url":"https:\/\/forum-mechaniczne.pl\/portal","home":"https:\/\/forum-mechaniczne.pl\/portal","gmt_offset":1,"timezone_string":"Europe\/Warsaw","page_for_posts":0,"page_on_front":2907,"show_on_front":"page","namespaces":["oembed\/1.0","yoast\/v1","health-check\/v1","robin-image-optimizer\/v1","jnews\/v1","ad-inserter\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/forum-mechaniczne.pl\/portal\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Adres URL zasobu pobieraj\u0105cego dane oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Adres URL zasobu pobieraj\u0105cego dane oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"oEmbed do wykorzystania.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Maksymalna szeroko\u015b\u0107 osadzonej ramki w pikselach.","type":"integer","default":600,"required":false},"maxheight":{"description":"Maksymalna wysoko\u015b\u0107 osadzonej ramki w pikselach.","type":"integer","required":false},"discover":{"description":"Czy wykonywa\u0107 zapytania oEmbed dla niezaufanych dostawc\u00f3w.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/oembed\/1.0\/proxy"}]}},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/ai_generator\/callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/ai_generator\/callback"}]}},"\/yoast\/v1\/ai_generator\/refresh_callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/ai_generator\/refresh_callback"}]}},"\/yoast\/v1\/ai_generator\/consent":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"consent":{"type":"boolean","description":"Whether the consent to use AI-based services has been given by the user.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/ai_generator\/consent"}]}},"\/yoast\/v1\/ai_content_planner\/banner_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/ai_content_planner\/banner_permanent_dismissal"}]}},"\/yoast\/v1\/ai_content_planner\/get_outline":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"type":"string","description":"The post type to get a content outline for.","required":true},"language":{"type":"string","description":"The language the content is written in.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true},"title":{"type":"string","description":"The title of the chosen content suggestion.","required":true},"intent":{"type":"string","description":"The intent of the chosen content suggestion.","required":true},"explanation":{"type":"string","description":"The explanation of the chosen content suggestion.","required":true},"keyphrase":{"type":"string","description":"The keyphrase of the chosen content suggestion.","required":true},"meta_description":{"type":"string","description":"The meta description of the chosen content suggestion.","required":true},"category":{"type":"object","properties":{"name":{"type":"string","required":true},"id":{"type":"integer","required":true}},"description":"The category of the chosen content suggestion. Use name \"\" and id -1 to indicate no category.","required":true},"recent_content":{"type":"array","maxItems":100,"items":{"type":"object","properties":{"title":{"type":"string","required":true,"maxLength":500},"description":{"type":"string","required":true,"maxLength":1000}},"additionalProperties":false},"description":"The recent content returned by the get_suggestions response.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/ai_content_planner\/get_outline"}]}},"\/yoast\/v1\/ai_content_planner\/get_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_type":{"type":"string","description":"The post type to get content suggestions for.","required":true},"language":{"type":"string","description":"The language the content is written in.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/ai_content_planner\/get_suggestions"}]}},"\/yoast\/v1\/ai\/free_sparks":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/ai\/free_sparks"}]}},"\/yoast\/v1\/ai_generator\/bust_subscription_cache":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/ai_generator\/bust_subscription_cache"}]}},"\/yoast\/v1\/ai_generator\/get_suggestions":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["seo-title","meta-description","product-seo-title","product-meta-description","product-taxonomy-seo-title","product-taxonomy-meta-description","taxonomy-seo-title","taxonomy-meta-description"],"description":"The type of suggestion requested.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the post is intended for.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/ai_generator\/get_suggestions"}]}},"\/yoast\/v1\/ai_generator\/get_usage":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_woo_product_entity":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/ai_generator\/get_usage"}]}},"\/yoast\/v1\/bulk_editor\/posts_content":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"ids":{"type":"array","minItems":1,"maxItems":20,"items":{"type":"integer","minimum":1},"description":"The IDs of the posts to return the content of. Accepts a comma separated list.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/bulk_editor\/posts_content"}]}},"\/yoast\/v1\/bulk_editor\/posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"content_type":{"type":"string","description":"The content type to fetch posts for.","required":true},"per_page":{"type":"integer","default":20,"minimum":1,"maximum":100,"description":"The number of posts to fetch.","required":false},"page":{"type":"integer","default":1,"minimum":1,"description":"The page of posts to fetch.","required":false},"search":{"type":"string","default":"","description":"The term to search posts by.","required":false},"status":{"type":"array","default":["publish","draft","pending","future"],"items":{"type":"string","enum":["publish","draft","pending","future"]},"description":"The post statuses to include.","required":false},"needs_improvement":{"type":"array","default":[],"items":{"type":"string","enum":["seo_title","meta_description","social_title","social_description"]},"description":"The fields to filter posts by; a field matches when it is empty, or (for search fields, while SEO analysis is enabled and the content type shows Yoast's controls and assessments) when its score needs improvement.","required":false},"include":{"type":"array","default":[],"maxItems":100,"items":{"type":"integer","minimum":1},"description":"Limits the posts to these post IDs, e.g. a selection carried over from the posts overview.","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/bulk_editor\/posts"}]}},"\/yoast\/v1\/bulk_editor\/update_scores":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post score updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/bulk_editor\/update_scores"}]}},"\/yoast\/v1\/bulk_editor\/update_search":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/bulk_editor\/update_search"}]}},"\/yoast\/v1\/bulk_editor\/update_social":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/bulk_editor\/update_social"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/myyoast\/status":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/myyoast\/status"}]}},"\/yoast\/v1\/myyoast\/refresh-status":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/myyoast\/refresh-status"}]}},"\/yoast\/v1\/myyoast\/register":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/myyoast\/register"}]}},"\/yoast\/v1\/myyoast\/registration":{"namespace":"yoast\/v1","methods":["PUT","DELETE"],"endpoints":[{"methods":["PUT"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/myyoast\/registration"}]}},"\/yoast\/v1\/myyoast\/authorize":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"return_url":{"type":"string","description":"URL to send the browser back to once the flow completes. Validated against the site host; an invalid or off-site URL is ignored.","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/myyoast\/authorize"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/wincher\/authorization-url":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/wincher\/authorization-url"}]}},"\/yoast\/v1\/wincher\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true},"websiteId":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/wincher\/authenticate"}]}},"\/yoast\/v1\/wincher\/keyphrases\/track":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/wincher\/keyphrases\/track"}]}},"\/yoast\/v1\/wincher\/keyphrases":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":false},"permalink":{"required":false},"startAt":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/wincher\/keyphrases"}]}},"\/yoast\/v1\/wincher\/keyphrases\/untrack":{"namespace":"yoast\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/wincher\/keyphrases\/untrack"}]}},"\/yoast\/v1\/wincher\/account\/limit":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/wincher\/account\/limit"}]}},"\/yoast\/v1\/wincher\/account\/upgrade-campaign":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/wincher\/account\/upgrade-campaign"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/action_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/yoast\/v1\/action_tracking"}]}},"\/health-check\/v1":{"namespace":"health-check\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"health-check\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/health-check\/v1"}]}},"\/health-check\/v1\/plugin-compat":{"namespace":"health-check\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/health-check\/v1\/plugin-compat"}]}},"\/robin-image-optimizer\/v1":{"namespace":"robin-image-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"robin-image-optimizer\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1"}]}},"\/robin-image-optimizer\/v1\/stats":{"namespace":"robin-image-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"scope":{"type":"string","default":"media-library","enum":["media-library","custom-folders","nextgen-gallery"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/stats"}]}},"\/robin-image-optimizer\/v1\/failures":{"namespace":"robin-image-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"scope":{"type":"string","default":"media-library","enum":["media-library","custom-folders","nextgen-gallery"],"required":false},"group":{"type":"string","required":true},"after":{"type":"string","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/failures"}]}},"\/robin-image-optimizer\/v1\/settings":{"namespace":"robin-image-optimizer\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/settings"}]}},"\/robin-image-optimizer\/v1\/settings\/reset":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/settings\/reset"}]}},"\/robin-image-optimizer\/v1\/backup":{"namespace":"robin-image-optimizer\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/backup"}]}},"\/robin-image-optimizer\/v1\/app-data":{"namespace":"robin-image-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"route":{"type":"string","enum":["bulk","settings","license","log"],"required":true},"scope":{"type":"string","default":"media-library","enum":["media-library","custom-folders","nextgen-gallery"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/app-data"}]}},"\/robin-image-optimizer\/v1\/backup\/restore":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/backup\/restore"}]}},"\/robin-image-optimizer\/v1\/diagnostics":{"namespace":"robin-image-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/diagnostics"}]}},"\/robin-image-optimizer\/v1\/failures\/item":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/failures\/item"}]}},"\/robin-image-optimizer\/v1\/optimization\/process":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/optimization\/process"}]}},"\/robin-image-optimizer\/v1\/optimization\/schedule\/start":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/optimization\/schedule\/start"}]}},"\/robin-image-optimizer\/v1\/optimization\/schedule\/stop":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/optimization\/schedule\/stop"}]}},"\/robin-image-optimizer\/v1\/server-status":{"namespace":"robin-image-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/server-status"}]}},"\/robin-image-optimizer\/v1\/background-test":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/background-test"}]}},"\/robin-image-optimizer\/v1\/delivery-test":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/delivery-test"}]}},"\/robin-image-optimizer\/v1\/delivery-test\/(?P<id>[a-z0-9]{12})":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/robin-image-optimizer\/v1\/counts\/attachments":{"namespace":"robin-image-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/counts\/attachments"}]}},"\/robin-image-optimizer\/v1\/counts\/thumbnails":{"namespace":"robin-image-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/counts\/thumbnails"}]}},"\/robin-image-optimizer\/v1\/counts\/summary":{"namespace":"robin-image-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/counts\/summary"}]}},"\/robin-image-optimizer\/v1\/folders\/browse":{"namespace":"robin-image-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/folders\/browse"}]}},"\/robin-image-optimizer\/v1\/folders":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/folders"}]}},"\/robin-image-optimizer\/v1\/folders\/(?P<uid>[a-f0-9]+)\/scan":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/robin-image-optimizer\/v1\/folders\/(?P<uid>[a-f0-9]+)":{"namespace":"robin-image-optimizer\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}]},"\/robin-image-optimizer\/v1\/license":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/license"}]}},"\/robin-image-optimizer\/v1\/subscribe":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/subscribe"}]}},"\/robin-image-optimizer\/v1\/avif-banner\/dismiss":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/avif-banner\/dismiss"}]}},"\/robin-image-optimizer\/v1\/notices\/(?P<notice>milestone|review|avif)\/dismiss":{"namespace":"robin-image-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/robin-image-optimizer\/v1\/log":{"namespace":"robin-image-optimizer\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/robin-image-optimizer\/v1\/log"}]}},"\/jnews\/v1":{"namespace":"jnews\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jnews\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1"}]}},"\/jnews\/v1\/searchImageLists":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/searchImageLists"}]}},"\/jnews\/v1\/searchPostsByTitleAndId":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/searchPostsByTitleAndId"}]}},"\/jnews\/v1\/searchTaxonomiesByTitleAndId":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/searchTaxonomiesByTitleAndId"}]}},"\/jnews\/v1\/searchAuthorsByNameAndId":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/searchAuthorsByNameAndId"}]}},"\/jnews\/v1\/updatePostMeta":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/updatePostMeta"}]}},"\/jnews\/v1\/updateMetaboxNotice":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/updateMetaboxNotice"}]}},"\/jnews\/v1\/dismissUpgradeNotice":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/dismissUpgradeNotice"}]}},"\/jnews\/v1\/upgradeNavNotice":{"namespace":"jnews\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET","DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/upgradeNavNotice"}]}},"\/jnews\/v1\/setOption":{"namespace":"jnews\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST","DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/setOption"}]}},"\/jnews\/v1\/getDashboardConfig":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/getDashboardConfig"}]}},"\/jnews\/v1\/savePanelOptions":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/savePanelOptions"}]}},"\/jnews\/v1\/restorePanelOptions":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/restorePanelOptions"}]}},"\/jnews\/v1\/importPanelOptions":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/importPanelOptions"}]}},"\/jnews\/v1\/exportPanelOptions":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/exportPanelOptions"}]}},"\/jnews\/v1\/getPlugins":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/getPlugins"}]}},"\/jnews\/v1\/validatePlugin":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/validatePlugin"}]}},"\/jnews\/v1\/checkPluginRemote":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/checkPluginRemote"}]}},"\/jnews\/v1\/managePlugin":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/managePlugin"}]}},"\/jnews\/v1\/resetLicense":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/resetLicense"}]}},"\/jnews\/v1\/getValidateNoticeLength":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/getValidateNoticeLength"}]}},"\/jnews\/v1\/getDemoList":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/getDemoList"}]}},"\/jnews\/v1\/manageDemo":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/manageDemo"}]}},"\/jnews\/v1\/manageCustomizer":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/manageCustomizer"}]}},"\/jnews\/v1\/newsletterSubscribe":{"namespace":"jnews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/jnews\/v1\/newsletterSubscribe"}]}},"\/ad-inserter\/v1":{"namespace":"ad-inserter\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ad-inserter\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/ad-inserter\/v1"}]}},"\/ad-inserter\/v1\/settings":{"namespace":"ad-inserter\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/ad-inserter\/v1\/settings"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ogranicz wyniki do wpis\u00f3w wybranych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Wyklucz wpisy przypisane do wybranych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz wyniki do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ogranicz wyniki do wpis\u00f3w przyporz\u0105dkowanych do jednego lub kilku status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit wyniku ustalony na podstawie relacji pomi\u0119dzy wieloma taksonomiami.\t","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Ograniczaj zestaw wynik\u00f3w do pozycji z okre\u015blonymi terminami z taksonomii categories.","type":["object","array"],"oneOf":[{"title":"Lista identyfikator\u00f3w termin\u00f3w","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminu w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Czy uwzgl\u0119dnia\u0107 terminy podrz\u0119dne w terminach ograniczaj\u0105cych wyniki.","type":"boolean","default":false},"operator":{"description":"Czy elementy musz\u0105 by\u0107 przypisane do wszystkich czy do wybranych termin\u00f3w?","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Ogranicz wyniki do element\u00f3w posiadaj\u0105cych wybrany termin w taksonomii categories.","type":["object","array"],"oneOf":[{"title":"Lista identyfikator\u00f3w termin\u00f3w","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminu w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Czy uwzgl\u0119dnia\u0107 terminy podrz\u0119dne w terminach ograniczaj\u0105cych wyniki.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Ograniczaj zestaw wynik\u00f3w do pozycji z okre\u015blonymi terminami z taksonomii tags.","type":["object","array"],"oneOf":[{"title":"Lista identyfikator\u00f3w termin\u00f3w","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminu w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Czy elementy musz\u0105 by\u0107 przypisane do wszystkich czy do wybranych termin\u00f3w?","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Ogranicz wyniki do element\u00f3w posiadaj\u0105cych wybrany termin w taksonomii tags.","type":["object","array"],"oneOf":[{"title":"Lista identyfikator\u00f3w termin\u00f3w","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminu w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Ogranicz zestaw wynik\u00f3w do przypi\u0119tych element\u00f3w.","type":"boolean","required":false},"ignore_sticky":{"description":"Czy ignorowa\u0107 przypi\u0119te wpisy?","type":"boolean","default":true,"required":false},"format":{"description":"Ogranicz zestaw wynik\u00f3w do element\u00f3w przypisanych do jednego lub wi\u0119cej wybranych format\u00f3w.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Format wpisu.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"jnews-multi-image_gallery":{"type":"array","title":"","description":"","default":[],"items":{"type":"object","properties":{"id":{"type":"integer"},"url":{"type":"string"}},"additionalProperties":false}},"jnews_single_post":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"}},"additionalProperties":false},"jnews_primary_category":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"}},"additionalProperties":false},"jnews_override_counter":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"},"enable_page_loop":{"type":"string"},"first_title":{"type":"string"},"second_title":{"type":"string"},"header_type":{"type":"string"},"header_background":{"type":"string"},"header_text_color":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"module":{"type":"string"},"main_custom_image_size":{"type":"string"},"second_custom_image_size":{"type":"string"},"boxed":{"type":"string"},"boxed_shadow":{"type":"string"},"box_shadow":{"type":"string"},"excerpt_length":{"type":"string"},"content_date":{"type":"string"},"date_custom":{"type":"string"},"content_pagination":{"type":"string"},"pagination_align":{"type":"string"},"show_navtext":{"type":"string"},"show_pageinfo":{"type":"string"},"post_sticky":{"type":"string"},"post_offset":{"type":"string"},"posts_per_page":{"type":"string"},"include_post":{"type":"string"},"exclude_post":{"type":"string"},"include_category":{"type":"string"},"exclude_category":{"type":"string"},"include_author":{"type":"string"},"include_tag":{"type":"string"},"exclude_tag":{"type":"string"},"sort_by":{"type":"string"},"show_post_title":{"type":"string"},"show_post_breadcrumbs":{"type":"string"},"show_post_featured":{"type":"string"},"show_post_meta":{"type":"string"},"share_position":{"type":"string"},"share_color":{"type":"string"},"override_view_counter":{"type":"string"},"view_counter_number":{"type":"string"},"override_share_counter":{"type":"string"},"share_counter_number":{"type":"string"},"override_like_counter":{"type":"string"},"like_counter_number":{"type":"string"},"override_dislike_counter":{"type":"string"},"dislike_counter_number":{"type":"string"}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Czy wpis powinien by\u0107 traktowany jako przypi\u0119ty.","type":"boolean","required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"categories":{"description":"Terminy przypisane do wpisu w taksonomii: category","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Terminy przypisane do wpisu w taksonomii: post_tag","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Nadpisz domy\u015bln\u0105 d\u0142ugo\u015b\u0107 zajawki.","type":"integer","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Format wpisu.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"jnews-multi-image_gallery":{"type":"array","title":"","description":"","default":[],"items":{"type":"object","properties":{"id":{"type":"integer"},"url":{"type":"string"}},"additionalProperties":false}},"jnews_single_post":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"}},"additionalProperties":false},"jnews_primary_category":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"}},"additionalProperties":false},"jnews_override_counter":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"},"enable_page_loop":{"type":"string"},"first_title":{"type":"string"},"second_title":{"type":"string"},"header_type":{"type":"string"},"header_background":{"type":"string"},"header_text_color":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"module":{"type":"string"},"main_custom_image_size":{"type":"string"},"second_custom_image_size":{"type":"string"},"boxed":{"type":"string"},"boxed_shadow":{"type":"string"},"box_shadow":{"type":"string"},"excerpt_length":{"type":"string"},"content_date":{"type":"string"},"date_custom":{"type":"string"},"content_pagination":{"type":"string"},"pagination_align":{"type":"string"},"show_navtext":{"type":"string"},"show_pageinfo":{"type":"string"},"post_sticky":{"type":"string"},"post_offset":{"type":"string"},"posts_per_page":{"type":"string"},"include_post":{"type":"string"},"exclude_post":{"type":"string"},"include_category":{"type":"string"},"exclude_category":{"type":"string"},"include_author":{"type":"string"},"include_tag":{"type":"string"},"exclude_tag":{"type":"string"},"sort_by":{"type":"string"},"show_post_title":{"type":"string"},"show_post_breadcrumbs":{"type":"string"},"show_post_featured":{"type":"string"},"show_post_meta":{"type":"string"},"share_position":{"type":"string"},"share_color":{"type":"string"},"override_view_counter":{"type":"string"},"view_counter_number":{"type":"string"},"override_share_counter":{"type":"string"},"share_counter_number":{"type":"string"},"override_like_counter":{"type":"string"},"like_counter_number":{"type":"string"},"override_dislike_counter":{"type":"string"},"dislike_counter_number":{"type":"string"}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Czy wpis powinien by\u0107 traktowany jako przypi\u0119ty.","type":"boolean","required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"categories":{"description":"Terminy przypisane do wpisu w taksonomii: category","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Terminy przypisane do wpisu w taksonomii: post_tag","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Format wpisu.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"jnews-multi-image_gallery":{"type":"array","title":"","description":"","default":[],"items":{"type":"object","properties":{"id":{"type":"integer"},"url":{"type":"string"}},"additionalProperties":false}},"jnews_single_post":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"}},"additionalProperties":false},"jnews_primary_category":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"}},"additionalProperties":false},"jnews_override_counter":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"},"enable_page_loop":{"type":"string"},"first_title":{"type":"string"},"second_title":{"type":"string"},"header_type":{"type":"string"},"header_background":{"type":"string"},"header_text_color":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"module":{"type":"string"},"main_custom_image_size":{"type":"string"},"second_custom_image_size":{"type":"string"},"boxed":{"type":"string"},"boxed_shadow":{"type":"string"},"box_shadow":{"type":"string"},"excerpt_length":{"type":"string"},"content_date":{"type":"string"},"date_custom":{"type":"string"},"content_pagination":{"type":"string"},"pagination_align":{"type":"string"},"show_navtext":{"type":"string"},"show_pageinfo":{"type":"string"},"post_sticky":{"type":"string"},"post_offset":{"type":"string"},"posts_per_page":{"type":"string"},"include_post":{"type":"string"},"exclude_post":{"type":"string"},"include_category":{"type":"string"},"exclude_category":{"type":"string"},"include_author":{"type":"string"},"include_tag":{"type":"string"},"exclude_tag":{"type":"string"},"sort_by":{"type":"string"},"show_post_title":{"type":"string"},"show_post_breadcrumbs":{"type":"string"},"show_post_featured":{"type":"string"},"show_post_meta":{"type":"string"},"share_position":{"type":"string"},"share_color":{"type":"string"},"override_view_counter":{"type":"string"},"view_counter_number":{"type":"string"},"override_share_counter":{"type":"string"},"share_counter_number":{"type":"string"},"override_like_counter":{"type":"string"},"like_counter_number":{"type":"string"},"override_dislike_counter":{"type":"string"},"dislike_counter_number":{"type":"string"}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Czy wpis powinien by\u0107 traktowany jako przypi\u0119ty.","type":"boolean","required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"categories":{"description":"Terminy przypisane do wpisu w taksonomii: category","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Terminy przypisane do wpisu w taksonomii: post_tag","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ogranicz wyniki do wpis\u00f3w wybranych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Wyklucz wpisy przypisane do wybranych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ogranicz wyniki do wpis\u00f3w z okre\u015blon\u0105 warto\u015bci\u0105 menu_order.","type":"integer","required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Ogranicz wyniki do element\u00f3w, kt\u00f3rych rodzice maj\u0105 wybrane identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Ogranicz zestaw wynik\u00f3w do wszystkich element\u00f3w z wyj\u0105tkiem tych o okre\u015blonym identyfikatorze rodzica.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz wyniki do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ogranicz wyniki do wpis\u00f3w przyporz\u0105dkowanych do jednego lub kilku status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"parent":{"description":"Identyfikator elementu nadrz\u0119dnego wpisu.","type":"integer","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Kolejno\u015b\u0107 wpis\u00f3w w stosunku do innych.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"jnews_page_loop":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"},"enable_page_loop":{"type":"string"},"first_title":{"type":"string"},"second_title":{"type":"string"},"header_type":{"type":"string"},"header_background":{"type":"string"},"header_text_color":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"module":{"type":"string"},"main_custom_image_size":{"type":"string"},"second_custom_image_size":{"type":"string"},"boxed":{"type":"string"},"boxed_shadow":{"type":"string"},"box_shadow":{"type":"string"},"excerpt_length":{"type":"string"},"content_date":{"type":"string"},"date_custom":{"type":"string"},"content_pagination":{"type":"string"},"pagination_align":{"type":"string"},"show_navtext":{"type":"string"},"show_pageinfo":{"type":"string"},"post_sticky":{"type":"string"},"post_offset":{"type":"string"},"posts_per_page":{"type":"string"},"include_post":{"type":"string"},"exclude_post":{"type":"string"},"include_category":{"type":"string"},"exclude_category":{"type":"string"},"include_author":{"type":"string"},"include_tag":{"type":"string"},"exclude_tag":{"type":"string"},"sort_by":{"type":"string"}},"additionalProperties":false},"jnews_single_page":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"},"enable_page_loop":{"type":"string"},"first_title":{"type":"string"},"second_title":{"type":"string"},"header_type":{"type":"string"},"header_background":{"type":"string"},"header_text_color":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"module":{"type":"string"},"main_custom_image_size":{"type":"string"},"second_custom_image_size":{"type":"string"},"boxed":{"type":"string"},"boxed_shadow":{"type":"string"},"box_shadow":{"type":"string"},"excerpt_length":{"type":"string"},"content_date":{"type":"string"},"date_custom":{"type":"string"},"content_pagination":{"type":"string"},"pagination_align":{"type":"string"},"show_navtext":{"type":"string"},"show_pageinfo":{"type":"string"},"post_sticky":{"type":"string"},"post_offset":{"type":"string"},"posts_per_page":{"type":"string"},"include_post":{"type":"string"},"exclude_post":{"type":"string"},"include_category":{"type":"string"},"exclude_category":{"type":"string"},"include_author":{"type":"string"},"include_tag":{"type":"string"},"exclude_tag":{"type":"string"},"sort_by":{"type":"string"},"show_post_title":{"type":"string"},"show_post_breadcrumbs":{"type":"string"},"show_post_featured":{"type":"string"},"show_post_meta":{"type":"string"},"share_position":{"type":"string"},"share_color":{"type":"string"}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Nadpisz domy\u015bln\u0105 d\u0142ugo\u015b\u0107 zajawki.","type":"integer","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"parent":{"description":"Identyfikator elementu nadrz\u0119dnego wpisu.","type":"integer","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Kolejno\u015b\u0107 wpis\u00f3w w stosunku do innych.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"jnews_page_loop":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"},"enable_page_loop":{"type":"string"},"first_title":{"type":"string"},"second_title":{"type":"string"},"header_type":{"type":"string"},"header_background":{"type":"string"},"header_text_color":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"module":{"type":"string"},"main_custom_image_size":{"type":"string"},"second_custom_image_size":{"type":"string"},"boxed":{"type":"string"},"boxed_shadow":{"type":"string"},"box_shadow":{"type":"string"},"excerpt_length":{"type":"string"},"content_date":{"type":"string"},"date_custom":{"type":"string"},"content_pagination":{"type":"string"},"pagination_align":{"type":"string"},"show_navtext":{"type":"string"},"show_pageinfo":{"type":"string"},"post_sticky":{"type":"string"},"post_offset":{"type":"string"},"posts_per_page":{"type":"string"},"include_post":{"type":"string"},"exclude_post":{"type":"string"},"include_category":{"type":"string"},"exclude_category":{"type":"string"},"include_author":{"type":"string"},"include_tag":{"type":"string"},"exclude_tag":{"type":"string"},"sort_by":{"type":"string"}},"additionalProperties":false},"jnews_single_page":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"},"enable_page_loop":{"type":"string"},"first_title":{"type":"string"},"second_title":{"type":"string"},"header_type":{"type":"string"},"header_background":{"type":"string"},"header_text_color":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"module":{"type":"string"},"main_custom_image_size":{"type":"string"},"second_custom_image_size":{"type":"string"},"boxed":{"type":"string"},"boxed_shadow":{"type":"string"},"box_shadow":{"type":"string"},"excerpt_length":{"type":"string"},"content_date":{"type":"string"},"date_custom":{"type":"string"},"content_pagination":{"type":"string"},"pagination_align":{"type":"string"},"show_navtext":{"type":"string"},"show_pageinfo":{"type":"string"},"post_sticky":{"type":"string"},"post_offset":{"type":"string"},"posts_per_page":{"type":"string"},"include_post":{"type":"string"},"exclude_post":{"type":"string"},"include_category":{"type":"string"},"exclude_category":{"type":"string"},"include_author":{"type":"string"},"include_tag":{"type":"string"},"exclude_tag":{"type":"string"},"sort_by":{"type":"string"},"show_post_title":{"type":"string"},"show_post_breadcrumbs":{"type":"string"},"show_post_featured":{"type":"string"},"show_post_meta":{"type":"string"},"share_position":{"type":"string"},"share_color":{"type":"string"}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Kolejno\u015b\u0107 wpis\u00f3w w stosunku do innych.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"jnews_page_loop":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"},"enable_page_loop":{"type":"string"},"first_title":{"type":"string"},"second_title":{"type":"string"},"header_type":{"type":"string"},"header_background":{"type":"string"},"header_text_color":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"module":{"type":"string"},"main_custom_image_size":{"type":"string"},"second_custom_image_size":{"type":"string"},"boxed":{"type":"string"},"boxed_shadow":{"type":"string"},"box_shadow":{"type":"string"},"excerpt_length":{"type":"string"},"content_date":{"type":"string"},"date_custom":{"type":"string"},"content_pagination":{"type":"string"},"pagination_align":{"type":"string"},"show_navtext":{"type":"string"},"show_pageinfo":{"type":"string"},"post_sticky":{"type":"string"},"post_offset":{"type":"string"},"posts_per_page":{"type":"string"},"include_post":{"type":"string"},"exclude_post":{"type":"string"},"include_category":{"type":"string"},"exclude_category":{"type":"string"},"include_author":{"type":"string"},"include_tag":{"type":"string"},"exclude_tag":{"type":"string"},"sort_by":{"type":"string"}},"additionalProperties":false},"jnews_single_page":{"type":"object","title":"","description":"","default":[],"properties":{"format":{"type":"string"},"subtitle":{"type":"string"},"video":{"type":"string"},"gallery":{"type":"string"},"source_name":{"type":"string"},"source_url":{"type":"string"},"via_name":{"type":"string"},"via_url":{"type":"string"},"override_template":{"type":"string"},"override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"template":{"type":"string"},"single_blog_custom":{"type":"string"},"parallax":{"type":"string"},"fullscreen":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"share_position":{"type":"string"},"share_float_style":{"type":"string"},"show_share_counter":{"type":"string"},"show_view_counter":{"type":"string"},"show_featured":{"type":"string"},"show_post_meta":{"type":"string"},"show_post_author":{"type":"string"},"show_post_author_image":{"type":"string"},"show_post_date":{"type":"string"},"post_date_format":{"type":"string"},"post_date_format_custom":{"type":"string"},"show_post_category":{"type":"string"},"show_post_reading_time":{"type":"string"},"post_reading_time_wpm":{"type":"string"},"post_calculate_word_method":{"type":"string"},"show_zoom_button":{"type":"string"},"zoom_button_out_step":{"type":"string"},"zoom_button_in_step":{"type":"string"},"show_post_tag":{"type":"string"},"show_prev_next_post":{"type":"string"},"show_popup_post":{"type":"string"},"show_comment_section":{"type":"string"},"number_popup_post":{"type":"string"},"show_author_box":{"type":"string"},"show_post_related":{"type":"string"},"show_inline_post_related":{"type":"string"}},"additionalProperties":false}},"override_image_size":{"type":"string"},"image_override":{"type":"array","items":{"type":"object","properties":{"_key":{"type":"string"},"single_post_thumbnail_size":{"type":"string"},"single_post_gallery_size":{"type":"string"}},"additionalProperties":false}},"trending_post":{"type":"string"},"trending_post_position":{"type":"string"},"trending_post_label":{"type":"string"},"sponsored_post":{"type":"string"},"sponsored_post_label":{"type":"string"},"sponsored_post_name":{"type":"string"},"sponsored_post_url":{"type":"string"},"sponsored_post_logo_enable":{"type":"string"},"sponsored_post_logo":{"type":"string"},"sponsored_post_desc":{"type":"string"},"disable_ad":{"type":"string"},"id":{"type":"string"},"hide":{"type":"string"},"enable_page_loop":{"type":"string"},"first_title":{"type":"string"},"second_title":{"type":"string"},"header_type":{"type":"string"},"header_background":{"type":"string"},"header_text_color":{"type":"string"},"layout":{"type":"string"},"sidebar":{"type":"string"},"second_sidebar":{"type":"string"},"sticky_sidebar":{"type":"string"},"module":{"type":"string"},"main_custom_image_size":{"type":"string"},"second_custom_image_size":{"type":"string"},"boxed":{"type":"string"},"boxed_shadow":{"type":"string"},"box_shadow":{"type":"string"},"excerpt_length":{"type":"string"},"content_date":{"type":"string"},"date_custom":{"type":"string"},"content_pagination":{"type":"string"},"pagination_align":{"type":"string"},"show_navtext":{"type":"string"},"show_pageinfo":{"type":"string"},"post_sticky":{"type":"string"},"post_offset":{"type":"string"},"posts_per_page":{"type":"string"},"include_post":{"type":"string"},"exclude_post":{"type":"string"},"include_category":{"type":"string"},"exclude_category":{"type":"string"},"include_author":{"type":"string"},"include_tag":{"type":"string"},"exclude_tag":{"type":"string"},"sort_by":{"type":"string"},"show_post_title":{"type":"string"},"show_post_breadcrumbs":{"type":"string"},"show_post_featured":{"type":"string"},"show_post_meta":{"type":"string"},"share_position":{"type":"string"},"share_color":{"type":"string"}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ogranicz wyniki do wpis\u00f3w wybranych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Wyklucz wpisy przypisane do wybranych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Ogranicz wyniki do element\u00f3w, kt\u00f3rych rodzice maj\u0105 wybrane identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Ogranicz zestaw wynik\u00f3w do wszystkich element\u00f3w z wyj\u0105tkiem tych o okre\u015blonym identyfikatorze rodzica.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz wyniki do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Ogranicz wyniki do wpis\u00f3w przyporz\u0105dkowanych do jednego lub kilku status\u00f3w.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Ogranicz zestaw wynik\u00f3w do za\u0142\u0105cznik\u00f3w do wybranego typu.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Ogranicz zestaw wynik\u00f3w do za\u0142\u0105cznik\u00f3w do wybranego typu MIME.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"alt_text":{"description":"Tekst alternatywny wy\u015bwietlany zamiast za\u0142\u0105cznika.","type":"string","required":false},"caption":{"description":"Podpis za\u0142\u0105cznika.","type":"object","properties":{"raw":{"description":"Podpis za\u0142\u0105cznika, dok\u0142adnie taki jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Podpis HTML dla za\u0142\u0105cznik\u00f3w, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis za\u0142\u0105cznika.","type":"object","properties":{"raw":{"description":"Opis za\u0142\u0105cznika, dok\u0142adnie taki jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Opis HTML za\u0142\u0105cznika - gotowy do wy\u015bwietlania ","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Identyfikator wpisu powi\u0105zanego z za\u0142\u0105cznikiem.","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"Czy generowa\u0107 podrz\u0119dne miniaturki obrazka.","required":false},"convert_format":{"type":"boolean","default":true,"description":"Czy konwertowa\u0107 formaty obrazk\u00f3w.","required":false},"url":{"type":"string","format":"uri","description":"Adres URL zewn\u0119trznego obrazka do za\u0142adowania do multimedi\u00f3w, zamiast przesy\u0142ania pliku.","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"alt_text":{"description":"Tekst alternatywny wy\u015bwietlany zamiast za\u0142\u0105cznika.","type":"string","required":false},"caption":{"description":"Podpis za\u0142\u0105cznika.","type":"object","properties":{"raw":{"description":"Podpis za\u0142\u0105cznika, dok\u0142adnie taki jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Podpis HTML dla za\u0142\u0105cznik\u00f3w, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis za\u0142\u0105cznika.","type":"object","properties":{"raw":{"description":"Opis za\u0142\u0105cznika, dok\u0142adnie taki jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Opis HTML za\u0142\u0105cznika - gotowy do wy\u015bwietlania ","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Identyfikator wpisu powi\u0105zanego z za\u0142\u0105cznikiem.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unikatowy identyfikator za\u0142\u0105cznika.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"Adres URL do edytowanego obrazka.","type":"string","format":"uri","required":true},"modifiers":{"description":"Tablica edycji obrazka.","type":"array","minItems":1,"items":{"description":"Edycja obrazka.","type":"object","required":["type","args"],"oneOf":[{"title":"Odwracanie","properties":{"type":{"description":"Rodzaj odwracania.","type":"string","enum":["flip"]},"args":{"description":"Argumenty odwracania.","type":"object","required":["flip"],"properties":{"flip":{"description":"Kierunek odwracania.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Okre\u015bla, czy obr\u00f3ci\u0107 w kierunku poziomym.","type":"boolean"},"vertical":{"description":"Okre\u015bla, czy obr\u00f3ci\u0107 w kierunku pionowym.","type":"boolean"}}}}}}},{"title":"Obracanie","properties":{"type":{"description":"Typ obracania.","type":"string","enum":["rotate"]},"args":{"description":"Argumenty obracania.","type":"object","required":["angle"],"properties":{"angle":{"description":"K\u0105t obrotu zgodnie z ruchem wskaz\u00f3wek zegara w stopniach.","type":"number"}}}}},{"title":"Kadruj","properties":{"type":{"description":"Typ kadrowania.","type":"string","enum":["crop"]},"args":{"description":"Skopiuj argumenty.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Pozycja od lewej do rozpocz\u0119cia przycinania jako procent d\u0142ugo\u015bci obrazu.","type":"number"},"top":{"description":"Pozycja od g\u00f3ry do rozpocz\u0119cia przycinania jako procent wysoko\u015bci obrazu.","type":"number"},"width":{"description":"Szeroko\u015b\u0107 kadrowania jako procent szeroko\u015bci obrazka.","type":"number"},"height":{"description":"Wysoko\u015b\u0107 kadrowania jako procent wysoko\u015bci obrazka.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Stopie\u0144 obr\u00f3cenia obrazu zgodnie z ruchem wskaz\u00f3wek zegara w stopniach. PRZESTARZA\u0141E: Zamiast tego u\u017cyj \u201emodyfikator\u00f3w\u201d.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Warto\u015b\u0107 procentowa obrazu - pozycja X przyci\u0119cia obrazu. PRZESTARZA\u0141E: Zamiast tego prosz\u0119 u\u017cy\u0107 `modyfikator\u00f3w`.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Warto\u015b\u0107 procentowa obrazu - pozycja Y przyci\u0119cia obrazu. PRZESTARZA\u0141E: Zamiast tego prosz\u0119 u\u017cy\u0107 `modyfikator\u00f3w`.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Warto\u015b\u0107 procentowa obrazu - d\u0142ugo\u015b\u0107 przyci\u0119cia obrazu. PRZESTARZA\u0141E: Zamiast tego prosz\u0119 u\u017cy\u0107 `modyfikator\u00f3w`.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Warto\u015b\u0107 procentowa obrazu - wysoko\u015b\u0107 przyci\u0119cia obrazu. PRZESTARZA\u0141E: Zamiast tego prosz\u0119 u\u017cy\u0107 `modyfikator\u00f3w`.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Podpis za\u0142\u0105cznika.","type":"object","properties":{"raw":{"description":"Podpis za\u0142\u0105cznika, dok\u0142adnie taki jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Podpis HTML dla za\u0142\u0105cznik\u00f3w, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis za\u0142\u0105cznika.","type":"object","properties":{"raw":{"description":"Opis za\u0142\u0105cznika, dok\u0142adnie taki jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Opis HTML za\u0142\u0105cznika - gotowy do wy\u015bwietlania ","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"Identyfikator wpisu powi\u0105zanego z za\u0142\u0105cznikiem.","type":"integer","required":false},"alt_text":{"description":"Tekst alternatywny wy\u015bwietlany zamiast za\u0142\u0105cznika.","type":"string","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/sideload":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unikatowy identyfikator za\u0142\u0105cznika.","type":"integer","required":false},"image_size":{"description":"Rozmiar obrazka. Mo\u017ce to by\u0107 nazwa pojedynczego rozmiaru albo tablica nazw rozmiar\u00f3w, \u017ceby zarejestrowa\u0107 ten sam plik w wielu rozmiarach.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"convert_format":{"type":"boolean","default":true,"description":"Czy konwertowa\u0107 formaty obrazk\u00f3w.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/finalize":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unikatowy identyfikator za\u0142\u0105cznika.","type":"integer","required":false},"sub_sizes":{"description":"Tablica metadanych dotycz\u0105cych dodatkowych rozmiar\u00f3w zebranych z odpowiedzi na operacje sideloadu.","type":"array","default":[],"maxItems":100,"items":{"type":"object","properties":{"image_size":{"description":"Nazwa rozmiaru lub tablica nazw rozmiar\u00f3w, gdy ten sam plik jest zarejestrowany pod wieloma rozmiarami o takich samych wymiarach.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"width":{"type":"integer","minimum":1},"height":{"type":"integer","minimum":1},"file":{"type":"string","minLength":1},"mime_type":{"type":"string","pattern":"^image\/.*"},"filesize":{"type":"integer","minimum":1},"original_image":{"type":"string","minLength":1}}},"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz wyniki do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ogranicz wyniki do wpis\u00f3w przyporz\u0105dkowanych do jednego lub kilku status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit wyniku ustalony na podstawie relacji pomi\u0119dzy wieloma taksonomiami.\t","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Ograniczaj zestaw wynik\u00f3w do pozycji z okre\u015blonymi terminami z taksonomii menus.","type":["object","array"],"oneOf":[{"title":"Lista identyfikator\u00f3w termin\u00f3w","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminu w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Czy elementy musz\u0105 by\u0107 przypisane do wszystkich czy do wybranych termin\u00f3w?","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Ogranicz wyniki do element\u00f3w posiadaj\u0105cych wybrany termin w taksonomii menus.","type":["object","array"],"oneOf":[{"title":"Lista identyfikator\u00f3w termin\u00f3w","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminu w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Ogranicz wyniki do wpis\u00f3w z okre\u015blon\u0105 warto\u015bci\u0105 menu_order.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Tytu\u0142 obiektu.","type":["string","object"],"properties":{"raw":{"description":"Tytu\u0142 obiektu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML obiektu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Rodzina pierwotnie reprezentowanych obiekt\u00f3w, na przyk\u0142ad \u201epost_type\u201d lub \u201etaxonomy\u201d.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Nazwa statusu obiektu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"Identyfikator elementu nadrz\u0119dnego dla obiektu.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Tekst atrybutu title odno\u015bnika dla elementu menu.","type":"string","required":false},"classes":{"description":"Nazwy klas odno\u015bnika dla elementu menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Opis elementu menu.","type":"string","required":false},"menu_order":{"default":1,"description":"Identyfikator w bazie danych dla elementu nav_menu_item, kt\u00f3ry jest elementem nadrz\u0119dnym menu tego elementu, je\u015bli istnieje, w przeciwnym razie 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Typ pierwotnie reprezentowanego obiektu, na przyk\u0142ad \u201ekategoria\u201d, \u201ewpis\u201d lub \u201eza\u0142\u0105cznik\u201d.","type":"string","required":false},"object_id":{"default":0,"description":"Identyfikator w bazie danych oryginalnego obiektu, kt\u00f3ry reprezentuje wybran\u0105 pozycj\u0119 menu, np.  identyfikator wpisu i term_id dla kategorii.","type":"integer","minimum":0,"required":false},"target":{"description":"Atrybut target odno\u015bnika dla elementu menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Adres URL do kt\u00f3rego prowadzi element menu.","type":"string","format":"uri","required":false},"xfn":{"description":"Relacja XFN odno\u015bnika w elemencie menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Poj\u0119cia przypisane do obiektu w taksonomii o nazwie: nav_menu","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"title":{"description":"Tytu\u0142 obiektu.","type":["string","object"],"properties":{"raw":{"description":"Tytu\u0142 obiektu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML obiektu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Rodzina pierwotnie reprezentowanych obiekt\u00f3w, na przyk\u0142ad \u201epost_type\u201d lub \u201etaxonomy\u201d.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Nazwa statusu obiektu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"Identyfikator elementu nadrz\u0119dnego dla obiektu.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Tekst atrybutu title odno\u015bnika dla elementu menu.","type":"string","required":false},"classes":{"description":"Nazwy klas odno\u015bnika dla elementu menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Opis elementu menu.","type":"string","required":false},"menu_order":{"description":"Identyfikator w bazie danych dla elementu nav_menu_item, kt\u00f3ry jest elementem nadrz\u0119dnym menu tego elementu, je\u015bli istnieje, w przeciwnym razie 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Typ pierwotnie reprezentowanego obiektu, na przyk\u0142ad \u201ekategoria\u201d, \u201ewpis\u201d lub \u201eza\u0142\u0105cznik\u201d.","type":"string","required":false},"object_id":{"description":"Identyfikator w bazie danych oryginalnego obiektu, kt\u00f3ry reprezentuje wybran\u0105 pozycj\u0119 menu, np.  identyfikator wpisu i term_id dla kategorii.","type":"integer","minimum":0,"required":false},"target":{"description":"Atrybut target odno\u015bnika dla elementu menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Adres URL do kt\u00f3rego prowadzi element menu.","type":"string","format":"uri","required":false},"xfn":{"description":"Relacja XFN odno\u015bnika w elemencie menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Poj\u0119cia przypisane do obiektu w taksonomii o nazwie: nav_menu","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego dla obiektu.","type":"integer","minimum":0,"required":false},"title":{"description":"Tytu\u0142 obiektu.","type":["string","object"],"properties":{"raw":{"description":"Tytu\u0142 obiektu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML obiektu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Rodzina pierwotnie reprezentowanych obiekt\u00f3w, na przyk\u0142ad \u201epost_type\u201d lub \u201etaxonomy\u201d.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Nazwa statusu obiektu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Tekst atrybutu title odno\u015bnika dla elementu menu.","type":"string","required":false},"classes":{"description":"Nazwy klas odno\u015bnika dla elementu menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Opis elementu menu.","type":"string","required":false},"menu_order":{"description":"Identyfikator w bazie danych dla elementu nav_menu_item, kt\u00f3ry jest elementem nadrz\u0119dnym menu tego elementu, je\u015bli istnieje, w przeciwnym razie 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Typ pierwotnie reprezentowanego obiektu, na przyk\u0142ad \u201ekategoria\u201d, \u201ewpis\u201d lub \u201eza\u0142\u0105cznik\u201d.","type":"string","required":false},"object_id":{"description":"Identyfikator w bazie danych oryginalnego obiektu, kt\u00f3ry reprezentuje wybran\u0105 pozycj\u0119 menu, np.  identyfikator wpisu i term_id dla kategorii.","type":"integer","minimum":0,"required":false},"target":{"description":"Atrybut target odno\u015bnika dla elementu menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Adres URL do kt\u00f3rego prowadzi element menu.","type":"string","format":"uri","required":false},"xfn":{"description":"Relacja XFN odno\u015bnika w elemencie menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Poj\u0119cia przypisane do obiektu w taksonomii o nazwie: nav_menu","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz wyniki do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ogranicz wyniki do wpis\u00f3w przyporz\u0105dkowanych do jednego lub kilku status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit wyniku ustalony na podstawie relacji pomi\u0119dzy wieloma taksonomiami.\t","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Ograniczaj zestaw wynik\u00f3w do pozycji z okre\u015blonymi terminami z taksonomii wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista identyfikator\u00f3w termin\u00f3w","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminu w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Czy elementy musz\u0105 by\u0107 przypisane do wszystkich czy do wybranych termin\u00f3w?","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Ogranicz wyniki do element\u00f3w posiadaj\u0105cych wybrany termin w taksonomii wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista identyfikator\u00f3w termin\u00f3w","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminu w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"wp_pattern_category":{"description":"Terminy przypisane do wpisu w taksonomii: wp_pattern_category","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Nadpisz domy\u015bln\u0105 d\u0142ugo\u015b\u0107 zajawki.","type":"integer","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"wp_pattern_category":{"description":"Terminy przypisane do wpisu w taksonomii: wp_pattern_category","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"wp_pattern_category":{"description":"Terminy przypisane do wpisu w taksonomii: wp_pattern_category","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis szablonu.","type":"string","required":false},"status":{"description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Zaw\u0119\u017a u\u017cycie tylko dla wybranego identyfikatora wpisu.","type":"integer","required":false},"area":{"description":"Ogranicz do okre\u015blonego obszaru fragmenu szablonu.","type":"string","required":false},"post_type":{"description":"Typ wpisu, dla kt\u00f3rego chcesz pobra\u0107 szablony.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"default":"","description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Opis szablonu.","type":"string","required":false},"status":{"default":"publish","description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Uproszczona nazwa szablonu, dla kt\u00f3rego mo\u017cna uzyska\u0107 awaryjne rozwi\u0105zanie","type":"string","required":true},"is_custom":{"description":"Wskazuje, czy szablon jest w\u0142asny, czy stanowi cz\u0119\u015b\u0107 hierarchii szablon\u00f3w","type":"boolean","required":false},"template_prefix":{"description":"Prefiks szablonu dla tworzonego szablonu. S\u0142u\u017cy do wyodr\u0119bnienia g\u0142\u00f3wnego typu szablonu np. w `taksonomia-ksi\u0105\u017cki` wyodr\u0119bniamy `taksonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis szablonu.","type":"string","required":false},"status":{"description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis szablonu.","type":"string","required":false},"status":{"description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false},"area":{"description":"Gdzie cz\u0119\u015b\u0107 szablonu b\u0119dzie przeznaczona do u\u017cytku (nag\u0142\u00f3wek, stopka, itd.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Zaw\u0119\u017a u\u017cycie tylko dla wybranego identyfikatora wpisu.","type":"integer","required":false},"area":{"description":"Ogranicz do okre\u015blonego obszaru fragmenu szablonu.","type":"string","required":false},"post_type":{"description":"Typ wpisu, dla kt\u00f3rego chcesz pobra\u0107 szablony.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"default":"","description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Opis szablonu.","type":"string","required":false},"status":{"default":"publish","description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false},"area":{"description":"Gdzie cz\u0119\u015b\u0107 szablonu b\u0119dzie przeznaczona do u\u017cytku (nag\u0142\u00f3wek, stopka, itd.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Uproszczona nazwa szablonu, dla kt\u00f3rego mo\u017cna uzyska\u0107 awaryjne rozwi\u0105zanie","type":"string","required":true},"is_custom":{"description":"Wskazuje, czy szablon jest w\u0142asny, czy stanowi cz\u0119\u015b\u0107 hierarchii szablon\u00f3w","type":"boolean","required":false},"template_prefix":{"description":"Prefiks szablonu dla tworzonego szablonu. S\u0142u\u017cy do wyodr\u0119bnienia g\u0142\u00f3wnego typu szablonu np. w `taksonomia-ksi\u0105\u017cki` wyodr\u0119bniamy `taksonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis szablonu.","type":"string","required":false},"status":{"description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false},"area":{"description":"Gdzie cz\u0119\u015b\u0107 szablonu b\u0119dzie przeznaczona do u\u017cytku (nag\u0142\u00f3wek, stopka, itd.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego globalnej wersji styl\u00f3w.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator globalnej wersji styl\u00f3w.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Identyfikator motywu","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Identyfikator motywu","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"Identyfikator konfiguracji styl\u00f3w globalnych.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Style globalne","type":["object"],"required":false},"settings":{"description":"Ustawienia globalne","type":["object"],"required":false},"title":{"description":"Tytu\u0142 globalnej wariacji styl\u00f3w.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 globalnej odmiany styl\u00f3w, jaka istnieje w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz wyniki do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ogranicz wyniki do wpis\u00f3w przyporz\u0105dkowanych do jednego lub kilku status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Ogranicz wyniki do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Wersja schematu theme.json u\u017cywanego do ustawie\u0144 typografii.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"deklaracja font-family w formacie theme.json, zakodowana jako ci\u0105g znak\u00f3w.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"theme_json_version":{"description":"Wersja schematu theme.json u\u017cywanego do ustawie\u0144 typografii.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"deklaracja font-family w formacie theme.json, zakodowana jako ci\u0105g znak\u00f3w.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Identyfikator nadrz\u0119dnej rodziny kroju pisma dla odmiany.","type":"integer","required":true},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"Identyfikator nadrz\u0119dnej rodziny kroju pisma dla odmiany.","type":"integer","required":true},"theme_json_version":{"description":"Wersja schematu theme.json u\u017cywanego do ustawie\u0144 typografii.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"deklaracja font-face w formacie theme.json, zakodowana jako ci\u0105g znak\u00f3w.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Identyfikator nadrz\u0119dnej rodziny kroju pisma dla odmiany.","type":"integer","required":true},"id":{"description":"Unikatowy identyfikator odmiany kroju pisma.","type":"integer","required":true},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"Identyfikator nadrz\u0119dnej rodziny kroju pisma dla odmiany.","type":"integer","required":true},"id":{"description":"Unikatowy identyfikator odmiany kroju pisma.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/wpb_gutenberg_param":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz wyniki do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ogranicz wyniki do wpis\u00f3w przyporz\u0105dkowanych do jednego lub kilku status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/wpb_gutenberg_param"}]}},"\/wp\/v2\/wpb_gutenberg_param\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/wpb_gutenberg_param\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}}]},"\/wp\/v2\/wpb_gutenberg_param\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Identyfikator alfa-numeryczny dla typu tre\u015bci.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Identyfikator alfanumeryczny statusu.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym typem tre\u015bci.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Alfanumeryczny identyfikator taksonomii.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r wed\u0142ug atrybutu taksonomii.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Czy ukry\u0107 taksonomie nieprzypisane do \u017cadnych wpis\u00f3w.","type":"boolean","default":false,"required":false},"parent":{"description":"Ogranicz wyniki do taksonomii posiadaj\u0105cych okre\u015blony element nadrz\u0119dny.","type":"integer","required":false},"post":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym wpisem.","type":"integer","default":null,"required":false},"slug":{"description":"Ogranicz wyniki taksonomii do jednej lub wielu uproszczonych nazw.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":true},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"parent":{"description":"Identyfikator taksonomii nadrz\u0119dnej.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"parent":{"description":"Identyfikator taksonomii nadrz\u0119dnej.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w taksonomiach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r wed\u0142ug atrybutu taksonomii.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Czy ukry\u0107 taksonomie nieprzypisane do \u017cadnych wpis\u00f3w.","type":"boolean","default":false,"required":false},"post":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym wpisem.","type":"integer","default":null,"required":false},"slug":{"description":"Ogranicz wyniki taksonomii do jednej lub wielu uproszczonych nazw.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":true},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w taksonomiach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r wed\u0142ug atrybutu taksonomii.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Czy ukry\u0107 taksonomie nieprzypisane do \u017cadnych wpis\u00f3w.","type":"boolean","default":false,"required":false},"post":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym wpisem.","type":"integer","default":null,"required":false},"slug":{"description":"Ogranicz wyniki taksonomii do jednej lub wielu uproszczonych nazw.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":true},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false},"locations":{"description":"Po\u0142o\u017cenie przypisana do menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Czy automatycznie dodawa\u0107 strony najwy\u017cszego poziomu do tego menu.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false},"locations":{"description":"Po\u0142o\u017cenie przypisana do menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Czy automatycznie dodawa\u0107 strony najwy\u017cszego poziomu do tego menu.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w taksonomiach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r wed\u0142ug atrybutu taksonomii.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Czy ukry\u0107 taksonomie nieprzypisane do \u017cadnych wpis\u00f3w.","type":"boolean","default":false,"required":false},"post":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym wpisem.","type":"integer","default":null,"required":false},"slug":{"description":"Ogranicz wyniki taksonomii do jednej lub wielu uproszczonych nazw.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":true},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w taksonomiach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"default":"asc","description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu u\u017cytkownika.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Ogranicz wynik do u\u017cytkownik\u00f3w za pomoc\u0105 co najmniej jednej uproszczonej nazwy.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Ogranicz do zasob\u00f3w pasuj\u0105cych do co najmniej jednej z podanych r\u00f3l. Akceptowana jest lista rozdzielana przecinkami lub pojedyncza rola.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Ogranicz zestaw wynik\u00f3w do u\u017cytkownik\u00f3w z co najmniej jednym uprawnieniem. Akceptowana jest lista csv lub pojedyncze uprawnienie.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Ogranicza wyniki do u\u017cytkownik\u00f3w uznawanych za autor\u00f3w.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Ogranicz zestaw wynik\u00f3w do u\u017cytkownik\u00f3w, kt\u00f3rzy opublikowali wpisy.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","wpb_gutenberg_param":"wpb_gutenberg_param"}},"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Login u\u017cytkownika.","type":"string","required":true},"name":{"description":"Wy\u015bwietlana nazwa u\u017cytkownika.","type":"string","required":false},"first_name":{"description":"Imi\u0119 u\u017cytkownika.","type":"string","required":false},"last_name":{"description":"Nazwisko u\u017cytkownika.","type":"string","required":false},"email":{"description":"Adres email u\u017cytkownika.","type":"string","format":"email","required":true},"url":{"description":"Adres URL u\u017cytkownika.","type":"string","format":"uri","required":false},"description":{"description":"Opis u\u017cytkownika.","type":"string","required":false},"locale":{"description":"Ustawienia regionalne u\u017cytkownika.","type":"string","enum":["","en_US","pl_PL"],"required":false},"nickname":{"description":"Pseudonim u\u017cytkownika.","type":"string","required":false},"slug":{"description":"Identyfikator alfanumeryczny uzytkownika.","type":"string","required":false},"roles":{"description":"U\u017cytkownikowi przypisano wybrane role.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Has\u0142o u\u017cytkownika (nigdy do\u0142\u0105czane).","type":"string","required":true},"meta":{"description":"Pola meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Data i godzina aktualizacji preferencji.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator u\u017cytkownika.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator u\u017cytkownika.","type":"integer","required":false},"username":{"description":"Login u\u017cytkownika.","type":"string","required":false},"name":{"description":"Wy\u015bwietlana nazwa u\u017cytkownika.","type":"string","required":false},"first_name":{"description":"Imi\u0119 u\u017cytkownika.","type":"string","required":false},"last_name":{"description":"Nazwisko u\u017cytkownika.","type":"string","required":false},"email":{"description":"Adres email u\u017cytkownika.","type":"string","format":"email","required":false},"url":{"description":"Adres URL u\u017cytkownika.","type":"string","format":"uri","required":false},"description":{"description":"Opis u\u017cytkownika.","type":"string","required":false},"locale":{"description":"Ustawienia regionalne u\u017cytkownika.","type":"string","enum":["","en_US","pl_PL"],"required":false},"nickname":{"description":"Pseudonim u\u017cytkownika.","type":"string","required":false},"slug":{"description":"Identyfikator alfanumeryczny uzytkownika.","type":"string","required":false},"roles":{"description":"U\u017cytkownikowi przypisano wybrane role.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Has\u0142o u\u017cytkownika (nigdy do\u0142\u0105czane).","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Data i godzina aktualizacji preferencji.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator u\u017cytkownika.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w u\u017cytkownikach nie u\u017cywamy kosza.","required":false},"reassign":{"type":"integer","description":"Przypisz wpisy i odno\u015bniki usuni\u0119tego autora do autora o podanym identyfikatorze.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Login u\u017cytkownika.","type":"string","required":false},"name":{"description":"Wy\u015bwietlana nazwa u\u017cytkownika.","type":"string","required":false},"first_name":{"description":"Imi\u0119 u\u017cytkownika.","type":"string","required":false},"last_name":{"description":"Nazwisko u\u017cytkownika.","type":"string","required":false},"email":{"description":"Adres email u\u017cytkownika.","type":"string","format":"email","required":false},"url":{"description":"Adres URL u\u017cytkownika.","type":"string","format":"uri","required":false},"description":{"description":"Opis u\u017cytkownika.","type":"string","required":false},"locale":{"description":"Ustawienia regionalne u\u017cytkownika.","type":"string","enum":["","en_US","pl_PL"],"required":false},"nickname":{"description":"Pseudonim u\u017cytkownika.","type":"string","required":false},"slug":{"description":"Identyfikator alfanumeryczny uzytkownika.","type":"string","required":false},"roles":{"description":"U\u017cytkownikowi przypisano wybrane role.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Has\u0142o u\u017cytkownika (nigdy do\u0142\u0105czane).","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Data i godzina aktualizacji preferencji.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w u\u017cytkownikach nie u\u017cywamy kosza.","required":false},"reassign":{"type":"integer","description":"Przypisz wpisy i odno\u015bniki usuni\u0119tego autora do autora o podanym identyfikatorze.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"UUID dostarczony przez aplikacj\u0119 w celu jej jednoznacznej identyfikacji. Zaleca si\u0119 u\u017cywanie UUID v5 z adresem URL lub przestrzeni\u0105 nazw DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Nazwa has\u0142a aplikacji.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"UUID dostarczony przez aplikacj\u0119 w celu jej jednoznacznej identyfikacji. Zaleca si\u0119 u\u017cywanie UUID v5 z adresem URL lub przestrzeni\u0105 nazw DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Nazwa has\u0142a aplikacji.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz do komentarzy opublikowanych po dacie podanej w formacie ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ogranicz wyniki do komentarzy powi\u0105zanych z wybranym identyfikatorem u\u017cytkownika. Wymagana autoryzacja.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Wy\u0142\u0105cz komentarze powi\u0105zane z u\u017cytkownikami o identyfikatorach. Wymagana autoryzacja.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Ogranicz wyniki na podstawie adresu email autora. Wymagana autoryzacja.","format":"email","type":"string","required":false},"before":{"description":"Ogranicz do komentarzy opublikowanych przed dat\u0105 podan\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 za pomoc\u0105 trybuty komentarza.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Ogranicz wyniki do komentarzy powi\u0105zanych z okre\u015blonymi identyfikatorami element\u00f3w nadrz\u0119dnych.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Prosz\u0119 si\u0119 upewni\u0107, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory element\u00f3w nadrz\u0119dnych.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Ogranicz wyniki do komentarzy powi\u0105zanych z okre\u015blonymi identyfikatorami wpis\u00f3w.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Ogranicz do wybranego statusu komentarzy. Wymagana autoryzacja.","type":"string","required":false},"type":{"default":"comment","description":"Ogranicz do wybranego rodzaju  komentarzy. Wymagana autoryzacja.","type":"string","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"Identyfikator obiektu u\u017cytkownika, je\u017celi autor by\u0142 u\u017cytkownikiem.","type":"integer","required":false},"author_email":{"description":"Adres email autora komentarza.","type":"string","format":"email","required":false},"author_ip":{"description":"Adres IP autora komentarza.","type":"string","format":"ip","required":false},"author_name":{"description":"Wy\u015bwietlana nazwa autora komentarza.","type":"string","required":false},"author_url":{"description":"Adres URL autora komentarza.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Klient u\u017cytkownika autora komentarza.","type":"string","required":false},"content":{"description":"Tre\u015b\u0107 komentarza.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 komentarza, dok\u0142adnie takie jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL komentarza, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Data opublikowania komentarza w strefie czasowej witryny. ","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Data komentarza zosta\u0142a opublikowana jako GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"Identyfikator elementu nadrz\u0119dnego komentarza.","type":"integer","required":false},"post":{"default":0,"description":"Identyfikator powi\u0105zanego obiektu wpisu.","type":"integer","required":false},"status":{"description":"Stan komentarza.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status rozwi\u0105zania notatki","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unikatowy identyfikator komentarza.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Has\u0142o dla nadrz\u0119dnego wpisu (je\u015bli wpis jest chroniony has\u0142em).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unikatowy identyfikator komentarza.","type":"integer","required":false},"author":{"description":"Identyfikator obiektu u\u017cytkownika, je\u017celi autor by\u0142 u\u017cytkownikiem.","type":"integer","required":false},"author_email":{"description":"Adres email autora komentarza.","type":"string","format":"email","required":false},"author_ip":{"description":"Adres IP autora komentarza.","type":"string","format":"ip","required":false},"author_name":{"description":"Wy\u015bwietlana nazwa autora komentarza.","type":"string","required":false},"author_url":{"description":"Adres URL autora komentarza.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Klient u\u017cytkownika autora komentarza.","type":"string","required":false},"content":{"description":"Tre\u015b\u0107 komentarza.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 komentarza, dok\u0142adnie takie jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL komentarza, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Data opublikowania komentarza w strefie czasowej witryny. ","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Data komentarza zosta\u0142a opublikowana jako GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"Identyfikator elementu nadrz\u0119dnego komentarza.","type":"integer","required":false},"post":{"description":"Identyfikator powi\u0105zanego obiektu wpisu.","type":"integer","required":false},"status":{"description":"Stan komentarza.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status rozwi\u0105zania notatki","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unikatowy identyfikator komentarza.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false},"password":{"description":"Has\u0142o dla nadrz\u0119dnego wpisu (je\u015bli wpis jest chroniony has\u0142em).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"type":{"default":"post","description":"Ogranicz wyniki wyszukiwania do wybranego typu obiektu.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Ogranicz wyniki wyszukiwania do jednego lub wi\u0119cej podtyp\u00f3w obiektu.","type":"array","items":{"enum":["post","page","wpb_gutenberg_param","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"Wyklucz z wyniku okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zestaw wynik\u00f3w do okre\u015blonych identyfikator\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Zarejestrowana, unikalna nazwa bloku.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Atrybuty bloku.","type":"object","default":[],"required":false},"post_id":{"description":"Identyfikator kontekstu wpisu.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Przestrze\u0144 nazw bloku.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Przestrze\u0144 nazw bloku.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nazwa bloku.","type":"string","required":false},"namespace":{"description":"Przestrze\u0144 nazw bloku.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"themeisle_sdk_promotions":{"title":"","description":"","type":"string","required":false},"themeisle_sdk_promotions_otter_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_optimole_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_rop_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_neve_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_redirection_cf7_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_hyve_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_wp_full_pay_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_masteriyo_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_easy_mcp_installed":{"title":"","description":"","type":"boolean","required":false},"title":{"title":"Tytu\u0142","description":"Tytu\u0142 witryny.","type":"string","required":false},"description":{"title":"Slogan","description":"Slogan witryny.","type":"string","required":false},"url":{"title":"","description":"Adres URL witryny.","type":"string","format":"uri","required":false},"email":{"title":"","description":"Adres jest u\u017cywany do cel\u00f3w administracyjnych, takich jak powiadomienia o nowych u\u017cytkownikach.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Miasto w twojej strefie czasowej,","type":"string","required":false},"date_format":{"title":"","description":"Format daty dla wszystkich wyst\u0105pe\u0144","type":"string","required":false},"time_format":{"title":"","description":"Format czasu dla wszystkich wyst\u0105pe\u0144","type":"string","required":false},"start_of_week":{"title":"","description":"Numer dnia tygodnia, dla kt\u00f3rego powinien si\u0119 on zaczyna\u0107.","type":"integer","required":false},"language":{"title":"","description":"Kod ustawie\u0144 regionalnych WordPressa.","type":"string","required":false},"use_smilies":{"title":"","description":"W czasie wy\u015bwietlania zmienia emotikony :-) i :-P na grafiki.","type":"boolean","required":false},"default_category":{"title":"","description":"Domy\u015blna kategoria wpisu.","type":"integer","required":false},"default_post_format":{"title":"","description":"Domy\u015blny format wpisu.","type":"string","required":false},"posts_per_page":{"title":"Maksymalna liczba wpis\u00f3w na stron\u0119","description":"Maksymalna liczba wpis\u00f3w wy\u015bwietlanych na stronach bloga.","type":"integer","required":false},"show_on_front":{"title":"Poka\u017c na stronie g\u0142\u00f3wnej","description":"Co pokaza\u0107 na stronie g\u0142\u00f3wnej","type":"string","required":false},"page_on_front":{"title":"Strona strony g\u0142\u00f3wnej","description":"Identyfikator strony, kt\u00f3ra powinna by\u0107 wy\u015bwietlana na stronie g\u0142\u00f3wnej","type":"integer","required":false},"page_for_posts":{"title":"","description":"Identyfikator strony, kt\u00f3ra powinna wy\u015bwietla\u0107 najnowsze wpisy","type":"integer","required":false},"default_ping_status":{"title":"","description":"Pozwala na powiadomienia z innych witryn (pingbacki i trackbacki) w nowych artyku\u0142ach.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Zezwalaj na komentowanie nowych wpis\u00f3w","description":"Zezw\u00f3l na komentowanie nowych wpis\u00f3w.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Logo witryny.","type":"integer","required":false},"site_icon":{"title":"Ikonka","description":"Ikonka witryny.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Ogranicz wyniki do motyw\u00f3w posiadaj\u0105cych co najmniej jeden status.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Arkusz styl\u00f3w motywu jednoznacznie go identyfikuje.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"status":{"description":"Ogranicza wyniki do wtyczek o podanym statusie.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Uproszczona nazwa w katalogu wtyczek WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Status wtyczki.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Status wtyczki.","type":"string","enum":["inactive","active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator zarejestrowanego panelu bocznego","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Zagnie\u017cd\u017cone wid\u017cety.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator typu wid\u017cetu.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identyfikator typu wid\u017cetu.","type":"string","required":true},"instance":{"description":"Aktualne ustawienia instancji wid\u017cetu.","type":"object","required":false},"form_data":{"description":"Serializowane dane formularza wid\u017cetu do zakodowania w ustawieniach instancji.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identyfikator typu wid\u017cetu.","type":"string","required":true},"instance":{"description":"Aktualne ustawienia instancji wid\u017cetu.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Pasek boczny do zwracania wid\u017cet\u00f3w.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wid\u017cetu.","type":"string","required":false},"id_base":{"description":"Typ wid\u017cetu. Odpowiada identyfikatorowi typu wid\u017cetu.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Pasek boczny, do kt\u00f3rego nale\u017cy wid\u017cet.","type":"string","required":true},"instance":{"description":"Ustawienia instancji wid\u017cetu, je\u015bli s\u0105 obs\u0142ugiwane.","type":"object","properties":{"encoded":{"description":"Ustawienia instancji zakodowane Base64.","type":"string","context":["edit"]},"hash":{"description":"Hash kryptograficzny ustawie\u0144 instancji.","type":"string","context":["edit"]},"raw":{"description":"Niezakodowane ustawienia instancji, je\u015bli s\u0105 obs\u0142ugiwane.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Zakodowane w adresie URL dane z formularza wid\u017cetu. S\u0142u\u017cy do aktualizacji wid\u017cetu, kt\u00f3ry nie obs\u0142uguje instancji. Tylko zapisywanie.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wid\u017cetu.","type":"string","required":false},"id_base":{"description":"Typ wid\u017cetu. Odpowiada identyfikatorowi typu wid\u017cetu.","type":"string","required":false},"sidebar":{"description":"Pasek boczny, do kt\u00f3rego nale\u017cy wid\u017cet.","type":"string","required":false},"instance":{"description":"Ustawienia instancji wid\u017cetu, je\u015bli s\u0105 obs\u0142ugiwane.","type":"object","properties":{"encoded":{"description":"Ustawienia instancji zakodowane Base64.","type":"string","context":["edit"]},"hash":{"description":"Hash kryptograficzny ustawie\u0144 instancji.","type":"string","context":["edit"]},"raw":{"description":"Niezakodowane ustawienia instancji, je\u015bli s\u0105 obs\u0142ugiwane.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Zakodowane w adresie URL dane z formularza wid\u017cetu. S\u0142u\u017cy do aktualizacji wid\u017cetu, kt\u00f3ry nie obs\u0142uguje instancji. Tylko zapisywanie.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Czy wymusi\u0107 usuni\u0119cie wid\u017cetu, czy przenie\u015b\u0107 go na nieaktywny pasek boczny?","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Ogranicz wyniki wyszukiwania do pasuj\u0105cych blok\u00f3w.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","minLength":1,"required":false},"category":{"description":"Ogranicz wyniki do pasuj\u0105cych do kategorii.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Ogranicz wyniki do pasuj\u0105cych do s\u0142owa kluczowego.","type":"integer","minimum":1,"required":false},"slug":{"description":"Ogranicz wyniki do pasuj\u0105cych do wzorca (uproszczona nazwa).","type":"array","required":false},"offset":{"description":"Przesuni\u0119cie zestawu wynik\u00f3w o okre\u015blon\u0105 liczb\u0119 element\u00f3w.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Adres URL do przetworzenia.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Identyfikator alfanumeryczny dla po\u0142o\u017cenia menu.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Unikatowy identyfikator kategorii dzia\u0142ania.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Unikatowy identyfikator dzia\u0142ania.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Parametry wej\u015bciowe do wykonania dzia\u0142ania.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Ogranicz wyniki do dzia\u0142a\u0144 w okre\u015blonej kategorii dzia\u0142a\u0144.","type":"string","required":false},"namespace":{"description":"Ogranicz wyniki do mo\u017cliwo\u015bci w okre\u015blonej przestrzeni nazw.","type":"string","required":false},"meta":{"description":"Ogranicz wyniki do mo\u017cliwo\u015bci pasuj\u0105cych do wszystkich podanych p\u00f3l meta.","type":"object","properties":{"annotations":{"description":"Ogranicz wyniki do mo\u017cliwo\u015bci pasuj\u0105cych do podanych adnotacji behawioralnych.","type":"object","properties":{"readonly":{"description":"Czy zdolno\u015b\u0107 nie modyfikuje swojego \u015brodowiska.","type":["boolean","null"]},"destructive":{"description":"Czy zdolno\u015b\u0107 mo\u017ce wykonywa\u0107 destrukcyjne aktualizacje swojego \u015brodowiska.","type":["boolean","null"]},"idempotent":{"description":"Czy powtarzaj\u0105ce si\u0119 wywo\u0142ania z tymi samymi argumentami nie maj\u0105 dodatkowego efektu.","type":["boolean","null"]}},"additionalProperties":true}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Unikatowy identyfikator dzia\u0142ania.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"collection":{"description":"Ogranicz wyniki do ikonek nale\u017c\u0105cych do podanej uproszczonej nazwy kolekcji.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<collection>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"collection":{"description":"Ogranicz wyniki do ikonek nale\u017c\u0105cych do podanej uproszczonej nazwy kolekcji.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false}}}]},"\/wp\/v2\/icons\/(?P<name>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?\/[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nazwa ikonki.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/icon-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/icon-collections"}]}},"\/wp\/v2\/icon-collections\/(?P<slug>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Uproszczona nazwa kolekcji ikonek.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/view-config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"description":"Rodzaj podmiotu.","type":"string","required":true},"name":{"description":"Nazwa podmiotu.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/view-config"}]}}},"site_logo":0,"site_icon":3071,"site_icon_url":"https:\/\/forum-mechaniczne.pl\/portal\/wp-content\/uploads\/2020\/09\/cropped-favicon.png","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/forum-mechaniczne.pl\/portal\/wp-json\/wp\/v2\/media\/3071"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
